cKarlGo wrote:
When I say "custom," I'm referring to choices based on what options Winnebago provides. Nothing will be outside of those parameters. I want to delete things like the fireplace, which I consider rather useless and that takes up about 4-5 cu/ft of useful storage space on a coach that's already short on space in the galley (but that I otherwise like a lot).
go to any winnie dealer and go down the list of options. assuming that the fireplace is an option it can easily be deleted. if it is standard you are likely stuck with it.
can always be taken out and additional cabinetry installed if they still have that separate rebuild area that they had when I was there. or of course can locate a firm that would customize it for you.
bumpy
