pianotuna
May 27, 2013Nomad III
Hi,
Statement removed because it may be in error. The rest is still valid so I'm leaving it in place.
You could add some fans to help with cooling the outside part of the fridge sucking more air up the "chimney". When I did this my initial cool down to first cycle on 120 volts dropped from 12 hours to 6 hours.
You could also add a fan internally inside the actual fridge compartment.
38,768 PostsLatest Activity: Nov 21, 2015
