dougrainer
May 28, 2013Nomad
pianotuna wrote:
Hi Doug,
Can that "sleeve" also apply the 12 volt section on a 3 way fridge? Mine worked fine initially on 12 volt--but now hardly cools at all. How does one check this out?dougrainer wrote:
It is also possible the sleeve that the 120 element slides into has slightly separated from the burner flue tube which will cause a loss of cooling on 120. Doug
Yes, but a 12 volt heat element is NOT designed for cooling DOWN a refer, only for maintaining the existing temp while in transit. Doug
38,768 PostsLatest Activity: Nov 21, 2015
