Bordercollie
Jul 17, 2015Explorer
Inspection Points: Make sure to run the fridge overnight, before you take it for inspection, to verify that it cools properly. It should operate properly in propane or electric mode and switch from propane to electric automatically in "auto" mode. Start generator and then turn on roof air conditioner to make sure it cools properly by thermostat setting. While air conditioner is running, heat a cup of water in the microwave to verify that it works and that generator can run both air conditioner and microwave together. Run dash A/C to verify that it cools properly. Run furnace using thermostat and make sure it starts and heats properly. Make sure that all six tires are less than 4 years old by date codes and if older, and showing any sidewall cracks, replace before driving. Have the engine cooling system and brake system checked during the drive train inspection. Have brake fluid flushed/replaced. Have the awning set up, fabric and mechanicals inspected, and stowed as part of inspection. Have house batteries and converter charger inspected and tested as well as engine starting battery. Test all interior lights and vehicle lights. Check all faucets and plumbing including toilet and shower and fresh water pump for proper operation. Is there a spare tire mounted in the rear? Look for any evidence of water leak damage. Basics but important cost and safety items.
