Hank85713
Apr 23, 2017Explorer
I have same issue with the aspect from winnebago, Sent them an email and they claimed 'it is insulated' and that you cant see it! Will I will be putting something up there soon as it is Hot in Summer and Cold in winter from the area. The framing for the supports for the sound sytem is also pretty weak so will have to play by ear. We are having a metal building built which will use a foam board type insulation, will try to see if it is something that can be used. Pretty thin, but when we checked out builders work on others buildings the insulation seemed to work well. Will see in next 60 days. Already in 90's out here.
