C20's avatar
C20
Overheating issue
As i've posted before we have been having troubles with the engine overheating since the first trip we took in the motorhome. Took it to Freightliner twice under warranty and nothing found. Took it back three more times after warranty and put a temperature sensor in it, a thermostat, and finally pulled the radiators out and cleaned them.
I'm a retired FF and I had our FD mechanic do some research on the matter, and he found a service bulletin on the fan clutch. He came out and took it apart and sure enough it had the oil leak around it that meant the clutch was bad. Ticks me off Freightliner couldn't figure out the issue on their chassis! Oh and the fan clutch was $900!!
BTW,
The story is it would only overheat in traffic at the end of the day or if you stopped at a toll booth etc. Had to have run all day and got the heat in the motor, just idling in the morning etc, would not make it overheat.
If anyone has a similar issue or chassis PM me and I can send you the link to the service bulletin.
  • call there hot line and discuss the problem.have your paper work in hand and that they new there was a problem.
  • Now I know!! Wish I had known before all the wasted money. Ticks me off Freightliner didn't check it first!
  • I've had three fan clutch problems on two different engines. It's one of the first things I check when I have an overheating problem. One fan clutch went bad after a few months.
