duckiee
Jun 25, 2013Explorer
redsb3 wrote:
Can't help much with your problem but I sure hope you got it real cheap. From your description, almost sounds like somebody did an engine swap, from gas to diesel. Could explain why a lot of stuff isn't connected or doesn't work.
It seems like that is the case. There are two shifters. One on the dash, and one on the steering column. All the other Overlands that I have looked up like mine have either a diesel in the rear or gas engine in the front.
The speedometer is not connected to the transmission. The cable for it is just dangling underneath it. There is a 2 foot gap from the end of the cable to where it is supposed to be hooked up. I don't know if there is a cruse control missing, or the cable is just too short. Got to figure out how to get that working. I have someone trying to figure it out but he is not clear as to what exact chassis it is and where to find a part that would fix it.
And the brakes! Horrible!
38,782 PostsLatest Activity: Sep 10, 2026
