hanko
Oct 11, 2014Explorer
Ray & June wrote:hanko wrote:
Here is something you need to take into consideration. Only Tiffin and Newmar use the Ford 24,000 lbs chasis on the 35ft and larger gas coaches. All other use the 22,000. My buddy bought a new 37 Thor Challenger. Adding full gas,water hes at his max GWVR. Also the Fleetwood and Thor 36 and 37 ft coaches have a 228 inch wheel base, which is way to short for a coach that size
Winnebago uses 24,000 lb chassis on their Adventurer 37F, and a 26,000 lb chassis on the 38Q. Itasca does the same on their equivalent models.
Yes your right, but I didnt think he wanted to spend $180,000 on a Giant gas coach. I still should have mentioned that
38,780 PostsLatest Activity: Nov 24, 2017
