WyoTraveler
Oct 11, 2014Explorer
Ray & June wrote:hanko wrote:
Here is something you need to take into consideration. Only Tiffin and Newmar use the Ford 24,000 lbs chasis on the 35ft and larger gas coaches. All other use the 22,000. My buddy bought a new 37 Thor Challenger. Adding full gas,water hes at his max GWVR. Also the Fleetwood and Thor 36 and 37 ft coaches have a 228 inch wheel base, which is way to short for a coach that size
Winnebago uses 24,000 lb chassis on their Adventurer 37F, and a 26,000 lb chassis on the 38Q. Itasca does the same on their equivalent models.
My 34 ft Monaco is on a 24k chassis. Fiber glass roof, heat pumps, EMS, W/D, electric heater in wet bay, air bed in sofa, central vac. etc. Still finding stuff I didn't know it had. Charger keeps start battery charged when plugged in. All new for $110k. Dealers are out there if you search them out.
38,780 PostsLatest Activity: Nov 24, 2017
