Hank_MI
Dec 05, 2013Explorer
toolman1 wrote:
Having been a GM Master Tech, all of the above reply's are good, and I would consider checking each one, BUT, there is another possibility. Some of the Mark IV engines had their timing marks below the harmonic balancer @ a 6 o'clock position, if you were to imagine the harmonic balancer as a clock face. If the installed engine is a crate motor, the timing tab may be incorrect for you're application, or the installer may have overlooked swapping the tab to it's proper position.
He did mention crawling underneath to set the timing so I assume the tab is down in the 4 - 5 o'clock position and he's using number 5 cylinder. If he can set the timing at 16 with no ping that would be great. I would switch to mid-grade or premium gas if needed to get the timing up there. The increase in performance and timing will more than offset the increase in gas.
You can get a rebuild kit for the advance mechanism at just about any auto parts store. It should come with 3 sets of springs for the weights, light, medium, heavy. You want to go heavy enough so you have no mechanical advance at idle but not too heavy. You want all the mechanical advance in by 2500 rpm. Install the heavy set of springs so you know you have no mechanical advance at idle. Then drop down to medium, if the timing jumped up then that's too light. If it didn't then drop down to light. You can mix the springs, 1 light and 1 medium or 1 medium and 1 heavy. It takes some trial and error but it's worth it. Use the combination that gives no mechanical advance at idle, full advance by 2500.
Bottom line, 4* is no good. It will run like a dog and run hot.
38,769 PostsLatest Activity: Apr 03, 2026
