rgatijnet1 wrote:
Maybe these are the parts that you need: Suspension parts
Note that the upper and lower control arm assemblies come with the ball joints.
These parts are for 16 in wheels only. I called the 1 800 number also and they told me the same thing. I can see why it is easy for a shop to install the wrong part most are after market unless a supplier bought up OEM parts years ago. The lwr control arm parts installed on my MH two years ago were Dorman 520183 for the left side and 50-184 for the right side which is the one that failed. I found out these were for P-30 Chassis with drum brakes in the rear they do not sell control arms for disc brakes all around. What I found that disc brakes all around were installed on MH's that were heavier and the rear drums were for the lighter chassis. I have never heard of ball joints failing like this, just shearing the shaft right at the threads. You hear alot abound them wearing and being loose in the socket.
