dougrainer
Jun 25, 2019Nomad
P 30 front coil springs with the air bags. The Air bags are NOT a comfort installed system. They are required to be installed and inflated to get the chassis to correct driveability and weight classification for steering. Now, If the after market coil springs do that job, then get the coil springs replaced and forget about using the Air Bags as a replacement. That way you do not have to constantly air the bags up and check them or replace them when they wear out. Doug
PS, remember this is required for the aftermarket springs.
BE SURE TO HAVE YOUR FRONT AXLE WEIGHT BEFORE ORDERING. WE NEED THE ACTUAL WEIGHT AND NOT GVW OR WHAT IS LISTED ON THE VIN PLATE. PLEASE PUT THIS WEIGHT IN THE "ORDER NOTES" BOX AT CHECKOUT
