BrianinMichigan
Mar 01, 2016Explorer
Well Eddie, I just replaced the pump after dropping the tank. The main reason was there are a lot of people with units as old or older than mine that are having fuel hose cracking and sucking air. On my tank there was a custom hose that I had to have made up because it had hydraulic style fittings on the ends. There were 3 or 4 hoses that I replaced so if something was to happen down the road I could get to the rest. There was absolutely no way to get to the top of the tank without dropping it. I used a harbor freight hydraulic table to drop it. I had to jack up one side of the MH about 4 inches to be able to roll it out. It took awhile to find and order the intank pump. Make sure you get the correct "O" ring for sealing up the pump assembly. Now that I have done this my fuel gauge is off. Maybe that will be another day.
