lonfu
Mar 03, 2016Explorer
Depends, in tank units usually just die. Engine mounted units will feel like your running out of gas when you put a heavy load on the engine, then eventually die. I have 125k on my original 98 chevy in tank unit. My 2nd gas tank is on it's 3rd pump. That said, EGR valve and MAP sensors are usually pesky critters when it comes to maintenance. Also, if you are having higher rpm problems then look at the TPS sensor.
