Cousin_Eddy wrote:
Im thinking the fuel pump is the primary single point failure item. Probably the only thing that will stop the RV dead and require a tow. So, how you know where to put the hole under the bed? Gotta drop the tank first?
I would hope not for dropping the tank, although maybe a little if you can't line things up, any other way.
If you have a place directly above it, you're mostly there already, so it may take some feeling around, a mirror and flashlight, etc...etc...,but just be sure you measure everything twice and more.
start with a small hole and enlarge it little by little to get it just right. How large depends on your space and what you can purchase at a marine supply store or other for an access plate. It will sure save a bundle of everything, if you can accomplish this and of course if it's ever needed. Many could use it for generator rubber fuel hose failures and even if the fuel pump never goes out.
