lonfu
Oct 01, 2016Explorer
Update: Checked my engine readings. still getting negative fuel trim values, -5 to -7. Coach seems to be running perfect. Idle smooth, temp in a good range, gas mileage varies between 8mpg over passes and 11mpg the flats of the desert.
I'm tempted to replace the idle mix valve to see if that is what is causing the negative values. Any one have any experience with this?
