dougmac wrote:
mike brez wrote:
Looks and feels like bearing. I read the manual I have but 0.001-0.005 is almost like nothing. My manual says to remove cotter pin and tighten to 12 ft lbs while turning wheel then back off nut then hand tighten and back off one flat. Can the dust cap be removed without taking the brake assembly and rotor off?
Yes, you can just pop the cap off without removing anything but the cap. You shouldn't even need to take the wheel off.
If it is out of adjustment, I would seriously consider having them repacked.
Thanks Doug. I have wheel simulators so I have to take the lug nuts off anyway. The cap is pretty deep into the hub with very little room all around. There is no way to pry it off with a screw driver. Is there any special tool that will take it off? Just googled and found
This
