1969SSCamaro
Jul 26, 2014Explorer
With the engine running I used a heat gun to heat up the fuel pump relay, control module, ignition coil and underside of distributor with no failures. Also just recently realized the pickup coil would be a little more painful to replace then I orginally thought; did not realize I would have to pull distributor and disasemble/reassemble the shaft. Still considering my options...
38,766 PostsLatest Activity: Jan 10, 2026
