1969SSCamaro
Jul 28, 2014Explorer
enblethen wrote:
The fuel pump relay only operates for a few seconds when the ignition switch is turned on. This pressurizes the fuel system. After that the fuel pump circuit goes through the oil pressure gauge(at least on mine). My book shows the same for 1994-95
I performed a quick test yesterday while idling in the driveway and removed the fuel pump relay to determine if it would die immediately and it did? Not sure if that is a valid test and how it related to your MH?
Greg
38,766 PostsLatest Activity: Jan 10, 2026
