1969SSCamaro
Jul 28, 2014Explorer
enblethen wrote:
I do not think this is a valid test. One of the wires, "red" goes to the fuel pump prime connector through a normally closed contact.
Have you inspected the oil pressure senor for oil leak? Located in oil galley, left side of engine under the power steering pump.
Does your oil pressure gauge seem to be accurate?
No, but I will be sure to check that out, as it is very easy. THanks,
Greg
38,766 PostsLatest Activity: Jan 10, 2026
