Daveinet
Aug 14, 2014Explorer
sklonsdale wrote:Crank shaft position sensors are only used on sequential fuel injection. Throttle body ('95) does not use a crank position sensor.
The problem is the crankshaft sensor. This sensor controls the ignition timing. It happened to my 2001 Class A with the 454 engine.
This sensor is located on the bottom of the crankcase aimed at the flywheel.
38,766 PostsLatest Activity: Jan 10, 2026
