Regarding the Pac Brake pedal that had stopped working. I called Monaco tech and he said 98% of all pac brake problems are a bad pedal. ($80 + shipping) He also indicated that if I got a simple on off toggle switch and wired it with the two wires going to the Pac Brake pedal, it should work. I tried that, disconnecting the pedal but it did not activate the system and downshift the transmission. I've checked the two wires and they had 12 volts going to both sides, also checked the 10 amp engine brake fuse, which was ok. Also did a continuity check and both wires from the fuse box seem in tact. (Although when the I then called Pac Brake and he said if I wired two wires back to the engine compartment to the Pac Brake solenoid, and then connected them, the brake would function. I am out of my element at this time and don't want to experiment and will take the unit in to have it checked out. Pac Brake says some manufacturers put an in-line solenoid on the way back and he didn't know what this Monaco Dynasty had. Just FYI. I see in some posts that many don't care for the Pac Brake, but I'll tell you, in driving home, just having to manually gear down the transmission in lower gears, the pac brake makes a huge difference. I just had freightliner check my brakes and after 91,000 miles, I have 75% brake show life remaining!
