DSDP_Don
Jan 03, 2016Explorer
Just so you know, the Monaco products and a few other brands were prone to have the clear coat go bad around the roof line starting at the top edges of the caps and then down the sides, above the rain rail. The only correct repair is to have the upper edges repainted. The cost is about $3000.00. This happened to most between 5-7 years old.
So, in your search, you may not be able to escape some checking in the dark colors, but make sure you get on a ladder and check the roof edges. Once repaired, the roof will look great. It may be a negotiating factor.
38,782 PostsLatest Activity: Sep 02, 2026
