jesseannie
Aug 12, 2014Explorer
I think you are on the right track. The only problem I can foresee is the plywood joints. Because the rig flexes while driving, unlike a stationary house, you may get some movement there. If so it will crack the filler out and ruin your new paint job. I would buy some thin wood battens from the trim section at Lowes and install them over the joints and then paint everything.
As an option you could make sure you have extra paint then see if the joints crack with time and then install the batten if you need to??
jesseannie
jesseannie
38,769 PostsLatest Activity: Mar 31, 2026
