Mark_Spears
Aug 12, 2014Explorer
BuckBarker wrote:
"Pro-Flex" caulk between the joints will not crack. It's the best available for this application. It's moot now, but you did the right thing in removing the vinyl. Any primer and paint is only as good as it's substrate. No coating will prevent the vinyl from coming loose from the paneling.
Can I paint over this stuff? If not I might strip some Liam and glue it in the joints prior to sanding/ painting.. What do you think?
38,769 PostsLatest Activity: Mar 31, 2026
