JamesWillard
Dec 11, 2017Explorer
Thanks very much. I went through the BIRD and Trombetta troubleshooting. I found that the Trombetta Solenoid is ALWAYS energized. Disconnected the "Relay" wire at the BIRD and it de-energizes. With it energized, the Coach Batteries are still not charging. That's not even possible since the Chassis batteries are charging normally. However, the Coach batteries charge normally on GEN or Shore Power. I've been checking wiring and found nothing loose. Have not really gotten started checking fuses . . .
38,769 PostsLatest Activity: Dec 31, 2014
