boomerdude
Jun 05, 2021Explorer
Thank you all for such intuitive thoughts and advice...openspaces and wanderingaimlessly you were pretty close to the issue...Though I had run the wire harness from the connector to the back of the fuse housing and discovered the wire gauge changed (?!) Thought, well heck, there's a splice/connector in-between the fuse back and the low beam connector...somewhere....took two big harnesses apart and low and behold, a connector. Took it apart, shook the DEBRIS out of it, took a jewelers spike and cleaned the inside of the connector. Behold it works now! Thank you ALL for the fast response and God bless you all!
