dougrainer
Nov 05, 2020Nomad
9) LCI doesn't recommend installing the controller with a breaker, because it won't save a possible fault in the controller. It should be fused only. Do definitely try to find where the controller is, because if the room ever does stop moving, the light will flash and the flashes correspond to a fault code. And... You'll want to know where it's at in case you need to unplug the motor connectors, which allows them to freewheel.
False also. In my 12 years, I have NEVER had LCI state to ONLY use a ATC fuse. LOTS of Schwintek slide rooms have 15 amp resettable 12 volt Circuit Breakers. AND, in the hundreds of Schwinteks I have worked on, NONE had a failure that would be because of a resettable CB. Doug
38,782 PostsLatest Activity: Sep 10, 2026
