Frebrd wrote:
I assume they are the original units on a 2012 Thor. I just purchased the motorhome. Can I install or do I take the motorhome to a service provider? Do these fall under the kit years?
The warranty from Dometic is 1 year. The kit, if you are out of warranty is just a rubber damper feet for the compressor. This problem is not a warranty item unless you are still under the 1 year warranty. The original Penguins with the 410 coolant had this noise problem. They changed compressors once they realized the louder problem. You probably have one of the first Penguins before they fixed the problem. They will NOT offer any warranty assistance after the original warranty expired. IMO, the kit did not really change the noise that much. Doug
