Ivylog wrote:
While I do not like this look it would be worth checking with the building dept if you could add something like this to the existing house.
In your first post you said "but it doesn't have a basement." This implies that the lot is fairly level so you may not be able to do what I did... the MH bay is 4' lower than the house. Granted mine is two story, but even if only one, lowering the MH bay would help the looks.
Ivylog, you certainly have a nice set-up although the pic above yours is not too shabby. I like the way your RV garage door is somewhat hidden (not seen in this pic).
MM.
