Fastpaddler
Feb 06, 2015Explorer
OFDPOS wrote:
I'm going to go check out a 2006 Itasca Cambria 26A? Wednesday it has 14,500 on the OD I could only get a quick look at it last Sat.
But will be able to crawl over under and around it Wed.
Any special areas I need to be concerned about looking at ?
I know with the reg C to look ,touch and feel in every corner especially the overhead cab area.
Being as these don't have the hugh overhead ,still need to look in that area.
Any other typical or otherwise places I need to look at , any particular appliance's to look for or NOT to look for ??
Thanks for any input.
I had a 2005 Winnebago Aspect 26A for 2 years. Excellent and stable rv. It had good insulation and thermo windows plus Winnebago ducted vents for heat and aircon. I had the CONVERTER fail which became evident when the lights went out one night. I also had the slide-out screw type slide unit break a mount which was welded. Otherwise, I liked it a lot and the V10 was good for 12 or so mpg for us most of the time. I did not like the corner bed and found it awkward to get out of at night without crawling over my wife. And, as noted, it is hard to make up. Otherwise great.
38,780 PostsLatest Activity: Aug 05, 2026
