spotrot
Oct 20, 2013Explorer
Job completed. Works again. If I had to replace the plastic acme nut again, it would take less than 2 hours on the rear slide. (The front silde is harder to get to.) Removing the steel spash shield was the hardest part - it was not designed to be removed when the coach is on the frame.
I clean and lubed the slide armw with silicone spray; it felt like a reasonalbe amount of friction. I don't know why the nut failed but a recent tech notice said not to stop the slide while going in or out. So I'll try that and see what happens.
The parts used were:
(1) plastic acme nut 162832-01-702 nut $6.25
(2) 5/16 clevis pins 162832-01-700 clevis pint $8.05/ea
(12) plastic rivets 162832-01-701 rivet $2.05/ea
Q&A from Power gear in case it's of interest:
1. Do the actuator sensors need to be zeroed? [The instructions suggest that
retracting the slide fully and waiting 60 seconds is all that is needed]
!A.Reset the slide out by pressing the pin hole in the center of the wall switch. both light flash , release pin hole button. use in and out buttons to retract the slide out room completely in , release the buttons. Wait 1 minute or until the lights stop flashing and operate slide out as designed.
2. Does the acme nut need to be installed at a certain place on the acme
shaft? The old one was in pieces so no measurement could be made. [I think
this is not a problem: the acme nut will naturally be in the right place
when the shaft is turned to close the slide and all parts are reassembled]
2A. no. as you will follow step one procedure to time the rails.
3, Is there a way to test the current limit sensors to make sure power to
the motor shuts off before actuator gears or acme nuts are stripped?
3A. yes, if we know the slide out control box part number we can tell you the amp max rating and stall rating of the control program.
4. Do the FLS actuators have a brake function -- or should the slide be
strapped or braced when closed?
4A. No brake is on the slide out motors or rails. the gear box of the linear actuator hold the force of the slide out in while traveling , unless the slide out manufacturer has installed room lock in the roof or sides of the slide out room. Consult the coach manufacturer for that option for room locks.
38,774 PostsLatest Activity: Apr 26, 2026
