spotrot
Aug 28, 2016Explorer
If memory serves, if you can get to the pin that holds the worm gear shaft to the gearbox shaft, and to the two pins that connect the nut to the slide, the job is fairly easy.
The shaft and broken nut can then be pulled out after the plate on the end of the tube is removed. I had to support the slide to do that.
Email me if you'd like the couple photos and pdf files that may be of help.
38,777 PostsLatest Activity: Jun 28, 2025
