dougrainer
Jun 10, 2017Nomad
Ocean Mist wrote:dougrainer wrote:timmac wrote:
$1343.00 for the 3M protective mask on front that will turn yellow long before the paint goes bad than a $1000 to remove and touch up damage paint from removing.
I would rather deal with a few rock chips before the 3M mask ordeal.
Well if your buying used I guess that's not your cost but the 1st owner sure had to pay that.
The RV is 10 years old. What do you see wrong with the front Cap??????????????????? Doug
I have looked by I'm not sure what your referring about? little help...
Tinmac is claiming your unit has the 3M front cap clear mask and that because of that your front Cap PAINT is ruined and the 3M mask is defective, NOT true. I have worked on scores of Motorhomes with both 3M and other clear masks. As long as the paint was allowed to cure correctly before the mask is installed, there are no real problems with clear mask. IF the paint is not allowed to cure(dry) for a few weeks, then clear mask installation can cause problems. But I do agree, paint chips and bugs are not a big deal. Why pay for that clear mask? Doug
