- timmacExplorer$1343.00 for the 3M protective mask on front that will turn yellow long before the paint goes bad than a $1000 to remove and touch up damage paint from removing.
I would rather deal with a few rock chips before the 3M mask ordeal.
Well if your buying used I guess that's not your cost but the 1st owner sure had to pay that. - 1968mooneyExplorer
Ocean Mist wrote:
Anything that stands out as an issue or problematic parts?
Like the Aladdin system. Anyone upgrade to the Silverleaf system, and how is it once you did the upgrade? worth it?
I feel $250,000 would be a fair price. :h - 2oldmanExplorer IINot sure I follow you, but I was hoping the OP would know. As he hasn't taken possession yet ( or even bought it) he may not.
I just was curious if this 'solar charger' is worth anything close to a grand. 'Course if you can afford a $.5M coach you probably don't care. 2oldman wrote:
$1,185 for a maintainer? Please.. it has to be more than that, especially with 8 batteries and a resi fridge.
There's something odd going on here....
Look at the break down for the Solar charger. They list the optional residential refer and then the $1185. They add 4 more 6-volt batteries AND the Solar charger for that $1185. Doug- 2oldmanExplorer III would hope the OP would know.
- bluwtr49Explorer II
More than likely it's one or two 100 W panels with controller. - 2oldmanExplorer II$1,185 for a maintainer? Please.. it has to be more than that, especially with 8 batteries and a resi fridge.
There's something odd going on here.... - TwomedExplorerMore properly battery maintainer. Keeps starting batts topped up when parked.
- hohenwald48Explorer
2oldman wrote:
What exactly is a 'solar battery charger'?
A battery charger that works off solar. :h Or is it a charger that charges the sun's batteries? :) - 2oldmanExplorer IIWhat exactly is a 'solar battery charger'?
38,766 PostsLatest Activity: Jan 10, 2026
