Sandy___Shirley
Aug 29, 2015Explorer
No response yet for starting a “users group”, so let me give you an example of the types of problems I am trying to solve with this thread.
When we first got our U260, we had problems hearing it over the A/C when driving at high speeds. I actually called Pioneer and they said to ask the dealer to install the auxiliary speaker which the dealer did, but with little to no improvement.
We already knew about the page in the settings menu (touch the map, then “More…”, then settings) and you get to a control where you can adjust the 4 different volume levels including the spoken navigation commands. The factory rep did not mention the second volume control which is also not mentioned in the manual. There is an overall master volume control on the “Quick Menu”. There is a “Menu” button on the navigation map screen which, per the manual, takes you to the “Quick Menu” and that menu has a master volume control at the bottom of it. The default setting is about 50% which is not enough for you to hear commands over road and A/C noise.
Bottom line is that the dealer and tech support did not know enough to tell us how to increase the volume. The dealer actually did a free service upgrade installing the auxiliary speaker as if that was the problem and it was not done properly by Forest River. That is why I wanted to start a thread where owners of a specific navigation unit can help newbees with start up questions!
All of the answers are not intuitive and they are also not all in the manual!
