RVER
Oct 04, 2017Explorer
1) i usually pull antifreeze through all the pipes and faucets, not just blow them out 2) what is a bib valve? WHY do you not take the anode rod out. it needs to be replaced so the innerds of the hot water heater do not electrolsyse the inside so change out the anode rod is my best advice. I will if i can get the bugger out, seems welded to the threads.
38,780 PostsLatest Activity: Nov 24, 2017
