dennyida
Apr 22, 2015Explorer
We had the same problem with our granite ridge that's on a f450 chassis. If you look into past forums here you will find what the caster settings should be on the ford 450 chassis for your motor home. It should be around the +5 degree setting. When my wife and I took our motor home back to the shop for another alignment the shop manager thought I was nuts when I told him what to set the caster at. His settings on a 450 were for a van not a motor home. he set it up the way we wanted and all is good, even pulling our toad. GOOD LUCK
38,782 PostsLatest Activity: Sep 10, 2026
