Harvard
Apr 28, 2015Explorer
Nevadastar:
If I am right about where the caster is set from the factory, I am going to guess that your unit sits at about +4.0 to +4.5 degrees caster. I say this because, from your picture, your unit rides "fore to aft" level. So, if I am right about this, you will be able to achieve a caster of +6.0 to +6.5 degrees, which is good.
The way you can tell if you have a factory setting, I think, is the existing sleeve has a keyed tab that sits in the pinch part of the pinch bolt, like this example:
38,782 PostsLatest Activity: Sep 10, 2026
