Dale_Traveling
Jan 27, 2020Explorer II
Ford, not Thor, establishes the various weight limits of the chassis (GAWR, GVWR and GCWR) so you need to research using Ford as the base. Historically the limit has been 26,000 lbs for the F53 except for the largest of the chassis models which has a combined limit of 30,000 lbs.
Also, even though the coach is a Thor 2017 model the chassis model year can be an earlier version. You need to check the Ford incomplete vehicle stickers or decode the VIN to determine the exact chassis you have.
