RSchleder
Nov 07, 2012Explorer
Monkeyrun wrote:
It may well need seals but never owning anything with slides I would not know where the leak on them shows up. The other leak, the one that did the damage appears to be the window.
I commend you on your approach to purchasing your 1st motorhome. In my opinion you are doing EVERYTHING right in your search and evaluation of each coach. My suggestion is to keep looking and don't settle for a coach with leakage issues ( or any other significant issue for that matter). Keep on the course you have set, there are a lot of very nice, high quality older motorhomes out there and by using the approach you've developed, you WILL find the one for you without compromising your goals. Best of luck, keep up the good work, Ron
