Usmcsousa's avatar
Usmcsousa
PLEASE Help, its dead.
I have a 95 gulfstream sunstream gxl class a.
today I was fiddling around with the different systems to make sure winter hasn't silently destroyed anything.
well I started her up, checked some other systems,
figured I'd drop the leveling jacks.
I have a bigfoot Quadra eze II system. Not automatic leveing .
anyway jacks all worked, so I turned the coach engine off, turned the ignition key to the run position, then held the brake and used the "aux start" key on my leveling control panel. It tried to turn over for about 2 seconds and quit. Got a check engine light on the dash and cannot start the coach back up.
tried disconnect the battery,and retry. Nothing!
it basically clicks and won't crank.
did I really mess something up here or what? Looked behind the level control panel for a fuse. Can't find any, also checked my fuse box for any blown fuse, nothing.
any ideas?
