stugpanzer
Apr 01, 2019Explorer
FIRE UP wrote:
We just did the same exact thing in our '04 Itasca Horizon 36GD with the CAT C-7 330HP. It was dated, to say the least. So, I gutted the coach, and had all the carpet replaced with a much more modern color. Then, that prompted us to tear off all the old junk valances and I built all new ones out of 1/2 plywood. I had to build them 1" deeper than the original ones 'cause I knew someday we'd converting the junk pleated day-nighters to some dual roller types.
Well, we did all the upholstering on the new valances and long story short, we purchased all new dual rollers from Shade Pro and, wow, what a difference. I was thinking about eliminating the down arms of each valance but, those give a better range of privacy so, when I built new ones, I kept the same design.
Our coach now is so much more modern looking inside now. All that, along with a new, modern Flat screened TV that I precise fitted in the front cabinets all ties it all together. Waaaaaaaaaaaaay cheaper than upgrading to another coach.
Scott
Our privacy will come from the trim I install on the windows as the blinds will ride right on them. I used 1x6 pine for our boxes and will be using 1x wood for the trim mounting flat which will come out 3/4". We also want to tackle the floors too at some point.
