tiffinboy
Nov 08, 2013Explorer
Sully2 wrote:prism wrote:Mr.Mark wrote:
Meffrig, I certainly would plug in if you can. It will keep the batteries charged up and you can run the fridge on electric.
MM.
wont run the fridge and charger system if its a standard house 15 amp type plug in
Yes it will...
well obviously not always.In my bus If the batterys are low and the charger is asking for 30-50 amps my system on my 08 allegro bus wont let the ats engage.says warning low line voltage.I have to charge my batterys up if that low with a 15 amp charger then after that it works fine but I cant run a the norcold fridge and inverter/charger off a 15 amp line and be dependable in that if the fridge and the inverter/charger try to power up at the same time that's more than 15 amp draw and voltage drops so I make sure my fridge is off and all is well.My 02 bus worked the same way so I guess it depends?I will add Iam running through a 100 ft #10 cord
