- Mike_M2ExplorerI also always keep mine plugged in.I use mine about twice a month and it's always ready to go. I do the same with my boat...
- SolidAxleDurangExplorer II
reubenray wrote:
Will having it plugged into only a 15 amp outlet keep the batteries charged up? I am getting ready to get a slab installed at my house.
Yes. - reubenrayExplorerWill having it plugged into only a 15 amp outlet keep the batteries charged up? I am getting ready to get a slab installed at my house.
- SolidAxleDurangExplorer IIOh and BTW, mine is plugged in 24x7x365
pianotuna wrote:
Hi,
I would not plug in until 3 days before a trip.
Why not? - jerseyjimExplorerPlug in at home (110) OK. Don't use the a/c. But...unless you need the room in the fridge to put food in, why have it connected? All that ($$$) electronic stuff working when it does't have to? Plug it in for guests, of course.
Where my motorhome is between trips, I have no access to electricity. Two days before I leave for a trip, I turn the fridge on (gas) and a few hours later, it's cold. Bring it up to the house, THEN plug it in (orange extention cord from the garage) and pack the thing up.
Works for me....... - gboppExplorerI keep our Southwind plugged in 24/7 when it's parked at home.
- ArchHoaglandExplorer
tiffinboy wrote:
ArchHoagland wrote:
When you say you have the proper adapters to do this I wonder what you mean.
You shouldn't need an adapter if you have a 50 amp RV outlet.
50-30-15 pretty simple. Use em all the time allows u to plug in at home.Good nuff to run inverter charger is all
I don't see where he indicates he has 50 amp home outlet?
You are correct...he didn't say and that's why I asked the question.
You are assuming he has those adapters but there have been people on here who have plugged into 220 volt dryer outlets which will create a real problem.
Hence my question. - Pangaea_RonExplorerI keep mine plugged in 24/7 with a "smart" charger. I also use a timer on the outlet so that it only charges about 8 hours a day. We like to have the MH ready to go at any time, and we use it regularly throughout the year. We also do not "winterize" and keep a bit of heat and ventilation operational to keep things from freezing. We also lose power at home, and need to use it when there is a power outage.
- wny_pat1ExplorerA newer smart converter/charger will keep the batteries properly charged and maintained better than I can with a manual charger, or by plugging/unplugging it.
38,771 PostsLatest Activity: Apr 22, 2026
