Karsty
Oct 25, 2014Explorer
PLUMBING PROBLEM - Winnebago ERA
OK ... here's the problem. When the valve for the hot water tank is open (not on bypass) I get plenty of HOT water. When I move the single lever tap handle down to COLD ... nothing. No HOT or COLD water.
When I put the valve on HW tank on bypass I get plenty of COLD water from the fresh water tank BUT the tap lever is on the HOT water position.
When I put the tap lever down to the COLD water position it literally does not pump any water ... so if I want HOT water I have to open the HW tank bypass. If I want COLD water, I have to close the bypass valve on the HW tank.
Is this an indication that the single lever kitchen tap is malfunctioning?? I don't have this issue with the bathroom taps that have separate HOT & COLD water taps or the outside shower that has HOT & COLD water taps.
Any assistance would be appreciated.
