msmith1199
Sep 26, 2015Explorer II
And here's what you had to say in 2002 about a motorhome you owned then:
"New ultrasport. first 6 months,rear springs sag(had to ad air bags to hold rv up)floor sagged bad,everything quit working due to wiring all wrong,headliner came down,rear duals ground through main wiring,water leaks,dash heat quit,dash air works sometimes,roof air soaked cieling a destroyed it,black water tank shallow and plugs up daily. second 6 months,5 foot long metal heat shield fell off on freway almost causing serious accident,entry door rattles so bad you cant hear junk radio,freds rv wedged 2x4s under floor to hold it up (heres your new motorhome back),large bubbles in rubber roof,dash rattles bad all screws are falling out,replace both cracked exhaust manifolds,(no tow vehicle)replace privacy curtains stained by water leaks,rear hatch fell off on freeway,fiberglass delamination on hood,rear hatch,compartment doors,compartments sag in hot weather,and doors pop open,galley chairs wearing and tearing through(do no live in rv)9 k miles. Next year,replace cracked manifolds,and y pipe,taillight fell off motorhome,screws into fiberglass only,cant put fuel in,tube does not have enough angle,all the knobs on the stove broke,vent fan fell appart,all water and toilet connections started leaking(hand tight),hinges on flip up bed broke,bath skylight filled up with water,window trim keeps falling off throughout rv,(one screw holding it on),Well this piece of garbage now has 36k miles,replace cracked exhaust manifolds again,captains chairs are wearing through and tearing,floor now sagging bad in bedroom,and kitchen,couch is now wearing through and tearing. DAMON builds total JUNK,if you get a lawyer like we did,they will lie and discredit you till you give up,may they all rot in hell..................."
Why in the world would you keep buying motorhomes if they simply fall completely apart when you get them?
38,771 PostsLatest Activity: Apr 15, 2026
