rgatijnet1
May 26, 2018Explorer III
Sooner Schooner wrote:rgatijnet1 wrote:
I have used a SPT heat pump/AC unit for several years. It is a single hose unit and uses less then 10 amps. The model I used is WA-1061H. It makes a great addition on a hot day and we have used it as a heat pump in temps just below zero. I used it as an add on to my roof top AC.
I can't find what you're describing, is it mounted on your roof?
Go to Amazon and put in SPT WA-1061H. It is a portable unit. All of the heat generated by the unit is vented to the outside.
