Bill_Satellite
May 27, 2018Explorer II
We had to use a 10,000 BTU unit from Home Depot or Lowe's and it does a good job but as mentioned above, the heat from the hose puts a lot of heat back in the coach. The closer you can get to the exhaust window the better. We bought some fiberglass insulation with alum. backing and wrapped the entire thing which helped dramatically. The floor models do take up a lot of space but I don't have any window that would fit a window A/C unit. Do not bother with the units that do not use an exhaust hose as the others are trying to make the swamp cooler effect in your RV and it just doesn't cut it.
