martolina wrote:
I got a quote to fix my generator for $4000. I could purchase a brand new Onan 5500 for about $3500. . .I can't drop that much right now. Has anyone every "rigged" a portable generator so that it will function as the Onan would. . .remote start, fuel pump from the main gas tank?? Is this even possible?
If you can find a cheap Chinese unit that can be stuffed in there by removing the portability portion of it, the rest should be easy. Try to find one with it's own fuel pump, rather than gravity feed, to save a fuel pump mod. AS for the remote, I seldom use it and usually start up outside before getting underway, shutting off back there also at the next fuel stop or campground, so no biggie, if you'd like to save on that.
Temporarily, you can even use the little built in fuel tank that should already be mounted on the genset.
